Hydraulic Cylinder Repair Tips
If you’re disassembling the cylinder to replace seals, don’t waste a perfect opportunity to do a thorough inspection of all the parts. Check the rod for chrome cracking and look for any pitting or scoring. If the finish is not uniform all the way around, it could indicate that the rod is bent and needs
